Hi Daniel and the others,
I tried again to import that *.bil file, as some time has gone by since my initial attempts.
In general I have to admit that I am a newbee to GIS and my general approach to projections etc. is very much try and error ...
I am working in a Lat/Lon location, the cascadia.bil file reflects a UTM location - does that cause additional problems?
However, I tried to import it into both types of locations without success.
I get complaints about "bytes not match File size" regardless what I try ... (see below)
Torge
*** Lat/Lon location ***
GRASS:~/geodata/dem/cascadia > r.in.bin -s input=cascadia.bil output=cascadia.grass bytes=1 north=53 south=39 east=244 west=227
Using rows=14 cols=17
Bytes do not match File size
File Size 76589370 ... Total Bytes 238
Try bytes=321804 or adjusting input parameters
*** UTM location ***
GRASS:~/geodata/dem/cascadia > r.in.bin -s input=cascadia.bil output=cascadia.grass bytes=1 north=1710340.289 south=101590.289 east=749705.938 west=-738044.062
Using rows=1608749 cols=1487749
File Size 76589370 ... Total Bytes 1117932129
Try bytes=0 or adjusting input parameters
On Tue, 7 Oct 2003 17:04:21 -0700 (PDT), Daniel Victoria <daniel_victoria@yahoo.com> wrote:
You should be able to import the file using r.in.bin.
I don't have my linux box on now so I can't remember
the command but I think you must have the header file
with the same name as the bill file (just different
extension .bil and .hdr)Also, you will have to play arounf with the bite
swaping option. Can't remember now if the motorola
(sun) needs bite swap on or off. Import and check the
values, if they are off than change the biteswap.
Acording to what you sent, the values - before
correcting for the offset - should range from 400 to
something in the order of 5000Hope to have helped
Daniel
--- Torge Schuemann <ts@uvic.ca> wrote:
for quite a while I am trying to import a *.bil file
into GRASS 5.0.1 by
using various modules (r.in.bin and r.in.gdal).
I am not familliar with the *.bil format, but the
archive "cascdem.tar.gz"
I downloaded from
http://geopubs.wr.usgs.gov/open-file/of99-369/
includes
some meta data which I applied when using the import
modules.However, so far I haven't been lucky although I
think I more or less tried
every possible combination of the parameters given
below.As info for the data set itself: It contains a
250-meter digital elevation
model (DEM) for Cascadia (latitude 39N - 53N,
longitude 116W - 133W), a
region that encompasses the Cascade volcanic arc,
the Cascadia subduction
zone, and the Juan de Fuca Ridge system offshore
Washington (USA) and
British Columbia (Canada).Any help is appreciated, thank you all!
Cheers, Torge
Here below I copied the available information which
is included in the tar
archive.
***** cascadia.blw: *****
250.00000000000000
0.00000000000000
-250.00000000000000
-737919.06250000000000
1710215.28906250000000***** cascadia.hdr: *****
BYTEORDER M
LAYOUT BIL
NROWS 6435
NCOLS 5951
NBANDS 1
NBITS 16
BANDROWBYTES 11902
TOTALROWBYTES 11902
BANDGAPBYTES 0***** cascadia.prj *****
Projection LAMBERT
Zunits NO
Units METERS
Spheroid CLARKE1866
Xshift 0.0000000000
Yshift 0.0000000000
Parameters
41 30 0.000 /* 1st standard parallel
50 30 0.000 /* 2nd standard parallel
-124 30 0.000 /* central meridian
38 0 0.000 /* latitude of projection's origin
0.00000 /* false easting (meters)
0.00000 /* false northing (meters)***** cascadia.stx *****
1 5147 14378 9371.3 2076.8***** excerpts from README.txt *****
This report contains a 250-meter digital elevation
(latitude 39N - 53N, longitude 116W - 133W), a
Cascade volcanic arc, the Cascadia subduction zone,
Ridge system. The DEM is distributed as file
cascdem.tar.gz (39 MB; 78MB
uncompressed).The DEM contains elevation values in integer meters,
at regularly-spaced
points in a Lambert conformal conic projection with
standard parallels at
latitudes 41.5N and 50.5N, and a central longitude
of 124.5W (the
"Cascadia" projection.).To ease data transfer for the widest possible range
of users, the DEM is
distributed as a BIL (Band Interleave by Line) file,
produced with the ARC
GRIDIMAGE command. For grids (the ARC term for a DEM
in the form of a
regular array of height values), such files are more
compact than ARC
export (.e00) files and USGS DEM-format files, and
are much faster to
create and import. They can also be read by many
applications other than
ARC. cascadia.bil is such a file of binary integers.
Elevations are stored
in cascadia.bil as unsigned positive 2-byte binary
integers, in Motorola
byte-order (default for Sun hardware), with an
offset of 10000. That is,
203 meters is stored as 10203 meters, and values
less than 10000 represent
negative elevations. Values of 0 in cascadia.bil
represent no data. Values
are given by row, west to east, starting at the
north edge of the region.To convert CASCADIA files to an ARC grid
Assemble the cascadia.* files (.bil, .blw, .hdr,
prj; .stx is not
necessary) in one directory. Make this your
workspace.Arc: imagegrid cascadia casc1
Arc: grid
Grid: casc2 = con(casc1 <> 0, casc1 - 10000)
Grid: &sys cp cascadia.prj casc2/prj.adfIf you DESCRIBE casc2 in ARC, you should get
Description of Grid CASC2
Cell Size = 250.000 Data Type: Integer
Number of Rows = 6435 Number of Values = 8555
Number of Columns = 5951 Attribute Data
(bytes) = 8BOUNDARY STATISTICS
Xmin = -738044.062 Minimum Value =
-4853.000rs)
0.00000Xmax = 749705.938 Maximum Value = 4378.000
Ymin = 101590.289 Mean = -628.692
Ymax = 1710340.289 Standard Deviation =
2076.818COORDINATE SYSTEM
DESCRIPTIONProjection LAMBERT
Zunits UNKNOWN
Units METERS
Spheroid
CLARKE1866
Parameters:
41 30
0.000
50 30
0.000
central meridian
-124 30
0.00
38 0
0.000
0.00000
0.00000__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
Dr. Torge Schuemann
School of Earth and Ocean Sciences (SEOS)
University of Victoria
Tel.: (250) 721-6177
Fax.: (250) 472-4620
Email: ts@uvic.ca
Web Page: http://biogeochemistry.uvic.ca
Mailing address (mail and courier):
P.O. Box 3050
E-Hut, Room 135c
School of Earth and Ocean Sciences, University of Victoria
Victoria, British Columbia, V8W 2Y2, Canada
