[GRASSLIST:147] Problems with installation
I'm trying to install GRASS on an AMD64 machine running Fedore Core 4. I have downloaded the Fedore Core 4 files. I have installed many of the rpm's, but I cannot get gdal to install. It's unable to locate the libsqlite3.so.0 library. When I go to install it, it tells me it's installed already. So, if SQLlite is already installed, what's going wrong? Any ideas on how to fix this? GDAL is the part I really need to use.
Thank you,
Julie Tittler
need to use.
funny, it should be installed with sqlite:
http://rpmfind.net//linux/RPM/fedora/4/i386/sqlite-3.1.2-3.i386.html
rpm -q sqlite
Sqlite 3 may be installed, but it doesn't necessarily contain a file
called libsqlite3.so.0.
try
ls -l /usr/lib/libsqlite3.so*
and see what shows up. If something close is there, you might just need
to make a symlink to it with the desired name.
e.g.
cd /usr/local/lib
ln -s /usr/lib/libsqlite3.so libsqlite3.so.0
  or
ln -s /usr/lib/libsqlite3.so.0.8.6 libsqlite3.so.0
make sure /usr/local/lib is listed in /etc/ld.so.conf so it can find
your new link. If not, add it and run ldconfig (as root) to refresh the
installed library list.
Hamish
