[GRASSLIST:1472] HELP: driver database!
I want to use the database in Grass 5.0.2.
I have installed all the library except : motif, readline, lapac, blas!
The only driver that there is in the list of the database driver is the
odbc, but if I wanto to create a database with db.createdb I asked to use
another driver, but there isn't anyone excepted the odbc.
What can I do?
I've tried to installa all the library of SQL and My-SQL but the situation
doesn't change.
Thank you!
