I've used v.in.mif (version 5.0beta11.2) to convert the attached vector
file from MapInfo format to GRASS. It appears to work OK, but I cannot get
anything to display on the monitor. I assume that I've done something
improperly, but I cannot see what it is. I also ran 'g.region
vector=claims-map', then 'd.vect claims-map color=white' but that didn't
solve the problem.
I'd appreciate someone else doing this and, when you see the results in a
monitor, write and tell me what you entered for each option in v.in.mif.
Here are the specs for the region:
Projection: stp Nevada (32), Pershing County (27), western zone (2703)
Ellipsoid: grs80
Datum: nad83
Units: meters
North: 853468.62
East: 4641114.06
South: 819043.72
West: 4589016.45
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
(attachments)
claims.tgz (52.2 KB)
