When I use m.in.e00 to read in an ESRI_e00 file I get the message "region not specified use g.region".
The projection, coordinate system are provided in the metadata.
How do I find out the North,East,South and West edge of the e00 file?
Chris Maden
Hi Chris,
You must at least know something like number of rows
and collumns, cellsize and one of the corners, then
you can calculate your region by hand. In the metadata
isn't there anything like llcornerx? That's lower left
corner and so on...
Daniel
the metadata.
of the e00 file?
Chris Maden
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
m.in.e00 will do this for you. The message you get means that you haven't
set any region at all. This is strange, and may means that the location
is not correctly initialised...
You can try to use g.region before unsing m.in.e00 and put anything you want.
It doesn't matter. Then use m.in.e00 just with the file name. It should work.
But after that, you have to use "g.region rast=xxx" or "g.region vect=xxx",
depending on the type of the xxx.e00 you imported (grid or arc data),
followed by d.erase, so you can see your data with d.rast or d.vect.
Michel Wurtz - Auzeville-Tolosane
