[GRASSLIST:1507] using v.what to get info. of vector map
Trying to get information of a vector map, which
projection is set as longitude-latitude, i use the
command as following:
   cat ll_data | v.what map=I95
ll_data contains one longitude-latitude coordinates:
-71.3780 41.8900
(this point is in the I95)
and it give me the output:
  UTM - -71.38 41.89
   nothing found.
i guess the grass regards the ll coordinates as utm,
could anyone tell me what need to do to get expected
result?
thanks for your help.
--lu
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/
On Sat, Feb 24, 2001 at 04:33:38PM -0800, an lu wrote:
-71.3780 41.8900
  UTM - -71.38 41.89
   nothing found.
result?
What does "g.region -p" say about your database's coordinate system. If
it says, UTM, then that's a start...
Eric G. Miller <egm2@jps.net>
after "g.region -p", i can get:
projection: 3 (Latitude-Longitude)
zone: 0
north: ...
wrote:
> Hi,
the
coordinates:
> -71.3780 41.8900
> UTM - -71.38 41.89
> nothing found.
utm,
expected
> result?
Do You Yahoo!?
