Thanks, I've done everything...
My data are in a Lambert II projection.
And I'm working in lat-long coordinates...
I didn't find the projection "Lambert II étendu", which is used in France.
Is there any way to make the translation from this projection to lat-long or
another one, supported by Grass ?
thanks for your ideas
Gaetan
Le mer, 21 fév 2001, vous avez écrit :
On Wed, 21 Feb 2001, Gaetan GUYODO wrote:
> Which table do I open, and with which soft ?
Gaetan,
In MapInfo, open the table you want to translate to GRASS. Then select
(from the menus) Table | Export. The dialog box asks for a name of the
exported table (with the .MIF extension) and the directory in which it
should be written.Also, these are DOS/Windows files, so they have a cr/lf at the end of each
line. Run the utility, dos2unix, on them to change the end of line character
to a lf (`\n').Now you can move your data (the *.mif/*.mid files) to the directory in
which you have your GRASS data and run v.in.mif. With a bit of luck, it will
work on your data.Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
