[GRASSLIST:1535] r.in.tiff segfault
Ok folks,
Thanks for looking into this, here are the details of the r.in.tiff
output to try and identify the problem. Regarding the .tiff I've saved it
to .tiff from several programs (xv, ImageMagik convert, PhotoStyler
windows, gimp, the original is from ArcView image analysis module) just
to make sure that it wasn't the generator of the .tiff that was at fault,
all the same results. Anyway as r.in.tiff is segfaulting inmediately I
think the problem lies somewhere else.
John Simon Goodall wrote:
GRASS:~ > r.in.tiff
Segmentation fault
GRASS:~ > r.in.tiff input=pstrial.tiff output=pstrial -v
Segmentation fault
GRASS:~ > ldd /usr/local/grass5/etc/bin/cmd/r.in.tiff
        libtiff.so.3 => /usr/lib/libtiff.so.3 (0x4001b000)
        libz.so.1 => /usr/lib/libz.so.1 (0x4005b000)
        libm.so.6 => /lib/libm.so.6 (0x4006a000)
        libc.so.6 => /lib/libc.so.6 (0x40086000)
        /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
GRASS:~ > tiffinfo pstrial.tiff
pstrial.tiff: Warning, unknown field with tag 317 (0x13d) ignored.
pstrial.tiff: Warning, unknown field with tag 34391 (0x8657) ignored.
pstrial.tiff: Warning, unknown field with tag 34392 (0x8658) ignored.
TIFF Directory at offset 0x8
  Subfile Type: (0 = 0x0)
  Image Width: 1219 Image Length: 934
  Resolution: 1, 1 pixels/inch
  Bits/Sample: 8
  Compression Scheme: None
  Photometric Interpretation: RGB color
  Samples/Pixel: 3
  Rows/Strip: 1
  Planar Configuration: single image plane
Just as a reminder;
Slack 7.1
grass5.0beta11 compiled from source
latest libtiff, tiff-v3.5.6-beta
Simon.
J.Simon Goodall, Lic. Ea.Viamonte, C.C.8, 9420 Río Grande, TDF, Argentina
te:54.2964.430.861 fx:422.008 mob:155.69148 e-mail:sgoodall@global.com.ar
