Both r.in.png and r.out.png are failing to compile due to a missing file, namely pnm.h.
Where might I find that?
Carl Brown cbsled@ncia.net
Hallo,
I am trying to convert grid3 sample-datafile CloudLCP.992172300 into
Vis5d with r3.out.v5d but i get the following error
CloudLCP.992172300
<CloudLCP.992172300>
OPTION: Name for v5d output file
key: output
required: YES
enter option > proov.v5d
You have chosen:
output=proov.v5d
Is this correct? (y/n) [y]
FLAG: Set the following flag?
Use map coordinates instead of xyz coordinates?(y/n) [n]
FATAL ERROR: G3d_getFloatRegion: error in G3d_getTilePtr
The same error occurs also with r3.out.ascii
What i did wrong?
Ylle Straus
student from the University of Tartu
Estonia
PS i am using Slackware 7.1 operating system
and GRASS 5.0beta11_2 from binary distribution
I consider to move over to RedHat 6.2, should I?
Please install the "netpbm" package. Then they should compile.
Kind regards
Markus Neteler
On Sun, Mar 04, 2001 at 08:31:44PM +0200, Ülle Straus wrote:
Hallo,
Vis5d with r3.out.v5d but i get the following error...
> CloudLCP.992172300
<CloudLCP.992172300>OPTION: Name for v5d output file
key: output
required: YES
enter option > proov.v5dYou have chosen:
output=proov.v5d
Is this correct? (y/n) [y]FLAG: Set the following flag?
FATAL ERROR: G3d_getFloatRegion: error in G3d_getTilePtrThe same error occurs also with r3.out.ascii
What i did wrong?
Ylle Straus
EstoniaPS i am using Slackware 7.1 operating system
and GRASS 5.0beta11_2 from binary distributionI consider to move over to RedHat 6.2, should I?
Hi Ylle Straus,
your problem doesn't have to do with Slackware or Redhat.
It's simply the problem of 3D-GRASS which is quite instable
at time. We'll take it out of distribution for the stable
release and hope to fix it for GRASS 5.1.
Sorry, but we would need more 3D programmers to speed this up.
Kind regards
Markus Neteler
