[GRASSLIST:1605] problem in grass-5.0.3rc3_src
hello
I tried to compile grass-5.0.3rc3_src with postgresql support.
But ./config gave this error message.
"Unable to locate ODBC includes, sql.h ... no"
How can I solve the problem in the slackware 9.1 system ?
PS system runs on postgre out of grass
I will appreciate if anyone comes up with any idea
regards
Ahmet Temiz
General Directory of Disaster Affairs
Ankara TURKEY
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
1. PostgreSQL support doesn't depend upon ODBC; you can use
--without-odbc and still use the *.pg commands.
2. To build the ODBC driver, you need the UnixODBC library, from
www.unixodbc.org. All external dependencies are listed in the
REQUIREMENTS.html file.
