Hamish,
Thanks for bringing up that point. Fortunately, the coastline I'm reporting
lengths on is a 'final' product released by another gov't department, and so
is likely to be the authoritative source for quite some time (presumably).
Interesting links you sent.
I ended up doing pretty much what you described, using Michael's nice
v.extract interface in gis.m. Exporting vector SQL queries is easier than
doing the same in Arc now, as I was happy to demonstrate to an Arc-using
colleague.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: GRASSLIST@baylor.edu
Sent: 3/15/2006 7:41 PM
Subject: Re: [GRASSLIST:138] How to report length totals for all lines
matching specific ID
I have a vector of a coastline; the coast is segmented into different
coastal types, according to unique IDs:CAT Class_ID CLASS SEG_LENGTH
1 5 Rock Cliff 56.789000
2 7 Barrier Beach 13.450000
....I successfully popluated the SEG_LENGTH column with the length of each
segment using v.to.db:v.to.db Coastal_Classes option=length type=line units=m
Now I want to report total lengths of each CLASS (i.e., total length
of all "Rock Cliff" segments, etc.)Any ideas?
maybe not the most efficient way, but:
v.extract out=rock_cliff where="CLASS = 'Rock Cliff'"
v.out.ascii.db rock_cliff column=SEG_LENGTH #from the wiki add-ons page
then add up in spreadsheet, matlab/octave, awk loop, etc.
Don't know of a UNIX command to do sums, but I'm sure there is one?
bc?
Note coastline length is a fractal problem and answers are only useful
when compared against the same dataset, e.g. as a percentage of the
whole. Even then trusting it is a bit dubious (same digitizer at the
same level of fatigue, etc).
see-
http://mathworld.wolfram.com/CoastlineParadox.html
http://www.vanderbilt.edu/AnS/psychology/cogsci/chaos/workshop/Fractals.
html
http://en.wikipedia.org/wiki/How_Long_Is_the_Coast_of_Britain%3F_Statist
ical_Self-Similarity_and_Fractional_Dimension
Hamish
