I've tried to install grass 5.7 on MacX:
the make command gives the following error:
gcc -L/sw/lib -L/sources/grass57_exp_2003_10_25/dist./lib -dynamiclib -Wl,-flat_namespace,-U,_cuserid -L/sw/lib -L/sources/grass57_exp_2003_10_25/dist./lib \
OBJ./get_proj.o OBJ./do_proj.o OBJ./convert.o OBJ./datum.o OBJ./ellipse.o -lgrass_gis -lgrass_datetime -lintl -lproj -o /sources/grass57_exp_2003_10_25/dist./lib/libgrass_gproj.dylib
ld: Undefined symbols:
_OSRDestroySpatialReference
_OSRExportToPrettyWkt
_OSRExportToWkt
_OSRGetAttrValue
_OSRImportFromProj4
_OSRMorphToESRI
_OSRNewSpatialReference
/usr/bin/libtool: internal link edit command failed
make[2]: *** [/sources/grass57_exp_2003_10_25/dist./lib/libgrass_gproj.dylib] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
An alternative is to download precompiled binaries:
http://mpa.itc.it/markus/grass57/macosx/index.html
If you installed GDAL from FINK, it is missing OGR.
That's why it won't compile. Try the GDAL-CVS or fetch
GDAL/OGR for MacOSX from above site.
Markus Neteler <neteler@itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Hello Markus
> _OSRExportToWkt
> _OSRGetAttrValue
> _OSRImportFromProj4
> _OSRMorphToESRI
> make[2]: ***
I don't think that was the problem. I have #ifdef HAVE_OGR statements
bounding the parts of the gproj library that depend on OGR, and the
configure script specifically checks 'gdal-config --ogr-enabled' before
defining HAVE_OGR so this shouldn't happen. The gproj library would just
compile but would simply be missing the functions that depend on OGR.
I think the problem will have been solved since we added the '-undefined
suppress' switch to the OSX linking line in aclocal.m4.
I also think this means all the EXTRA_LIBS lines can be removed from the
library Makefiles again now but since I haven't got an OSX system to
test it I don't want to risk doing this. It's nice to see the Makefiles
tidy and as short as possible though.
Paul
On Mon, Dec 08, 2003 at 09:39:22PM +0000, Paul Kelly wrote:
Hello Markus
> > _OSRExportToWkt
> > _OSRGetAttrValue
> > _OSRImportFromProj4
> > _OSRMorphToESRI
> > make[2]: ***
OK, so Giacomo should try to upgrade from CVS (both 5.3 and 5.7, see
the INSTALL file of 5.7 how to do that).
Generally agreed - someone with MacOSX system may try and post the
result. I am too far from a Mac to try myself.
