[GRASSLIST:162] [Bug 123707] sci-geosciences/grass-6.0.2 (version bump)
---------- Messaggio inoltrato ----------
------- Comment #3 from marazm@navigator.lv 2006-03-16 03:14 PST -------
Renamed old ebuild and it compiles && works fine.
Small fix is required: remove BLAS and LAPACK dependencies. Currently they
are unused. Fixes bug #125561
Moving from 6.0.1 to 6.0.2 also fixes bug #119133
Configure bugmail: http://bugs.gentoo.org/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
"E' molto più bello sapere qualcosa di tutto, che tutto di una cosa (Blaise
Pascal)."
GENTOO-GIS Development Team
jabber: casagrande@jabber.linux.it
(attachments)
[[Bug 123707] sci-geosciences/grass-6.0.2 (version bump)|attachment](upload://6NQR5PdA41oKTMC8NVdcGoTE0GU.2 (version) (593 Bytes)
I've installed the version of Lorenzo's binaries dated 11 March 2006, and have been unable to start Grass. I receive a message that Grass has unexpected quit before before any of the startup screens appear. I ran the grasslib.mpkg installer packaged with the release before installing the cvs file. I'm running OS X 10.4.5.
I wonder if anyone else has experienced similar problems.
Dave
Sorry about the subject line in my previous message. I’ve replaced it with one that’s more appropriate.
Dave
Begin forwarded message:
Date: March 17, 2006 6:22:13 AM GMT-05:00
To: “GrassList,” <GRASSLIST@baylor.edu>
Subject: Re: [GRASSLIST:162] Fwd: [Bug 123707] sci-geosciences/grass-6.0.2 (version bump)
I’ve installed the version of Lorenzo’s binaries dated 11 March 2006, and have been unable to start Grass. I receive a message that Grass has unexpected quit before before any of the startup screens appear. I ran the grasslib.mpkg installer packaged with the release before installing the cvs file. I’m running OS X 10.4.5.
Dave
Dave
Try this:
  • delete this file “/Users/your_name/Library/Preferences/com.lor.grass61cvs.plist”
  • restart grass61cvs
If this fails again wait next release …
and use old grass61cvs (030609).
Bye
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
ENEA - Ente Nazionale per le Nuove Tecnologie, l'Energia e l'Ambiente
ENEA - The Italian Agency for New Technologies, Energy and the Environment
__________________________________________________________________________
I am able to get Grass to start, but it crashes whenever I try to
import almost anything. I am using the most recent cvs version with
the new grasslibs on 10.4.5.
Mark
On 3/17/06, David Kindem <dkindem@chartermi.net> wrote:
Sorry about the subject line in my previous message. I've replaced it with
one that's more appropriate.
Dave
To: "GrassList," <GRASSLIST@baylor.edu>
(version bump)
Dave
Have fun or die trying - but try not to actually die.
I had done the same about two days ago. I installed the latest 6.1 cvs on my iBook (1.67 GHz G4 with I GB Ram running 10.4.5.) After the initial startup and crash, I was unable to start either Grass 6.1 or Grass 6.0. I ended up completely wiping the grasslib folder from the disk and reinstalling 6.0
Brian
Mark
Dave
(version bump)
Dave
J. Brian Adams
Asst. Professor of Computer Science
206 Stager Hall
Franklin & Marshall College
Lancaster, PA 17604-3003
(717) 291-3872
I've had problems since at least the last cvs version. These problems
exist on my powerbook and my macbook pro.
Anybody know if there's any work being put into a universal binary?
Mark
Brian
> Mark
>> replaced it with
>> Dave
>> From: David Kindem <dkindem@chartermi.net>
>> grass-6.0.2
>> (version bump)
>> 2006, and
>> I ran the
>> installing the cvs
>> Dave
J. Brian Adams
206 Stager Hall
(717) 291-3872
I've worked out a universal GRASS (most of it at least). I did this for the GRASS libraries I use in my GIS Libs installer, I just need to finish up and build a full GRASS.
I've been thinking of making a GRASS installer as an alternative to Lorenzo's - they'd be based on my Graphics Libs and GIS Libs packages, and not have Lorenzo's handy .app startup.
Mark
William Kyngesburye <kyngchaos@kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
Thanks, Lorenzo. Deleting the file solved the problem.
Dave
Dave
Try this:
Bye
A couple of ideas.
  1. To run 6.0 under OS X 10.4.5 you need to install a patch on Lorenzo’s web site.
  2. If you’ve done this, try starting using the “terminal” rather than the “x11” setting.
  3. Do you have x11? If not, you’ll need it to run GRASS, even if you use the OS X version of TclTk (unless you are using the most recent 6.1 cvs version and the new GIS Manager selected as the default interface).
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
From: Lorenzo Moretti lorenzo.moretti@bologna.enea.it
Date: Fri, 17 Mar 2006 15:56:58 +0100
To: David Kindem dkindem@chartermi.net
Cc: GRASSLIST@baylor.edu
Subject: [GRASSLIST:212] Re: Fwd: [Bug 123707] sci-geosciences/grass-6.0.2 (version bump)
Dave
Try this:
Bye
Lorenzo,
I’ve got the newest binary (11 March) installed. I’ve got the problem detailed below. If I delete the preferences file, GRASS opens. But once I’ve closed it, I have to delete the preferences file again in order for GRASS to open again. Obviously this is a problem if I have to delete this file each time I want to start GRASS. Do you have a fix for this yet?
Michael
phone: 480-965-6213
fax: 480-965-7671
Dave
Try this:
Bye
