[GRASSLIST:1620] Compile sdts2arc
I need to import USGS SDTS DEMs, and r.in.gdal is still not installed on my grass release on MacX.
For this resaon, I'm triyng to follow the method explained in http://grass.itc.it/faq/importing_usgs_7_5min.html, but I am not able to compile the sdts2arc.c program (the makefile does not work), required to transform the data from sdts format to arc format.
How can I compile sdts2arc.c ?
Giacomo
