[GRASSLIST:1625] d.zoom, mouse and clicks
Dear all,
I am just starting with GRASS and cannot manage with the d.zoom command. I am working on a portable computer (Compaq nx 7000) with a two-buttons mouse. The left click works well and fixes the first corner of a region, but the second left (or right) click does not set the window. Actually a second left click move the position of the first corner, and a right click quit.
Documentations and the GRASS dialog mention sometimes a "middle" button. Is this button necessary?
Any hint?
Thanks in advance...
Patrick Giraudoux
Patrick Giraudoux wrote:
Dear all,
click quit.
Any hint?
Use both buttons together as a middle mouse button if you don't have one.
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
click quit.
Yes. However:
1. On Unix/X11, you may be able to simulate it by pressing both
buttons simultaneously. For XFree86, this behaviour is enabled by use
of the Emulate3Buttons option in the XF86Config file.
2. For the "generic" Windows port (wingrass_generic), you can simulate
the middle button by using the left button while holding the Shift
key.
