[GRASSLIST:1635] 5.0b11 problem with d.mon
I just upgraded from b7 to b11 and I am getting the d.mon problem
that a few others mentioned. When I run d.mon start=x0 I get
Sorry, </usr/local/grass5/dev/fifo.1a> not available
Have GRASS adminstrator check etc/monitorcap file
Can't stat /usr/local/grass5/dev/fifo.1a
Problem selecting x0. Will try once more
I don't have an /etc/monitorcap file. How is this created? Also,
/usr/local/grass5/dev is a shell script, not a directory.
Brian
Hi Brian
I assume you have downloaded the source code tarball since this problem
hopefully doesn't appear in the binaries. Hopefully, all you need to do
is add one line to the Makefile and re-install. So, first run
make uninstall
Then change the Makefile around line 190 from this:
real-install: FORCE
        test -d ${INST_DIR} || ${MAKE_DIR_CMD} ${INST_DIR}
        test -d ${BINDIR} || ${MAKE_DIR_CMD} ${BINDIR}
to this:
real-install: FORCE
  test -d ${INST_DIR}/dev || ${MAKE_DIR_CMD} ${INST_DIR}/dev
Now you can run
make install
again and hopefully, everything wil be OK. Note that you may want to
make the same change in the Makefile.in file incase you ever run
configure again.
Please let me know if you have any other problems.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
