[GRASSLIST:165] Sum for an area
This is probably a very dumb question but I'm stuck... I need to
calculate the total precipitation over a basin. I have the annual
precip raster and the basin raster. So, I'm issuing the command
r.statistics base=sto_ica cover=ppt.81@cru method=sum output=test
And I get:
ERROR: This module currently only works for integer (CELL) maps
Of course I could easily convert the precip map (ppt.81) to integer
but I'm afraid that, since it's a big area, this could result in some
errors (sub-estimation in the final sum).
I'm sure there is another way to accomplish what I want, I just don't
know how. Or, should I not worry about errors (sub-estimations)?
Thanks
Daniel
On Thu, Mar 16, 2006 at 10:37:49AM -0300, Daniel Victoria wrote:
And I get:
yes, an annoying problem...
if you set a MASK for the basin, will
r.sum
do the job?
Thanks Markus! Silly me! MASK and r.sum does it.
Just for the record, I tested the sum with an FCELL map and a CELL and
the results differ by 600 mm (from 3208360.204620 to 3207755). This is
on a basin of 1311 cells (0.25 degrees resolution).
Once again, Thanks
Daniel
> Hi all,
> And I get:
r.sum
do the job?
> And I get:
> some errors (sub-estimation in the final sum).
> don't know how. Or, should I not worry about errors
> (sub-estimations)?
r.sum
do the job?
r.univar too; any thoughts from the list on if r.univar should report
sum in full instead of shortening to 1.23456e+07?
Hamish
And I get:
(sub-estimations)?
r.sum
do the job?
To me a shortened value doesn't make much sense.
