I have recently started to get commands terminating with a `bus error'. Some examples area d.what.vect (only when I use the postgresql query), ps.map, but only when processing a integer colortable (float colortables are fine) and when importing shapefiles. These used to work, and I think the problem might be my upgrade from Mac OS 10.2.5 to 10.2.6. This problem affects GRASS 5.0.0, 5.0.1 and 5.0.2.
Has anyone else experienced this?
David
Hello
I used to get a bus error on SGI IRIX when importing an area coverage with
v.in.shape (line coverages were all right). I discovered recently this was
because of a non-standard usage of the non-standard snprintf() function. I
fixed v.in.shape in CVS so if you try the latest CVS version and the bus
error goes away this might be a clue to the problem? I notice d.what.vect
also contains a call to snprintf(); I'm not sure about ps.map.
Paul Kelly
