[GRASSLIST:1670] r.statistics
Hi GRASS users,
I am using r.statistics in order to get max, and min values of elevation
(my cover map), based on 41 regions with unique integer cell values (my
base map). I use r.statistics as follows:
r.statistics base=base_map cover=elev_map method=max output=out_max
The module generates out_map with the only one region equal to the
smallest cell value in base_map. Both, base_map, and cover_map have no
category labels, but based on manual, cell values should be enough to
generate the map.
r.average, using the same approach works fine.
What am I doing wrong?
      Rado
Rado Bonk
Geography and Geology
UNO, Omaha, NE 68182-0199
rado@cosmos.unomaha.edu
http://rbonk.host.sk
