[GRASSLIST:1688] Stereo photogrammetry w/o known camera position
Hi GRASSlist,
has anybody implemented/used Stereo-0.2 together with Grass?
I myself used it a lot during the last month in order to generate
cheap DEM Data for our telescope project. (http://dts.astronomy.net)
It seemed to be logical to offer it in a polished form to other GIS
(eh GRASS users) users as well. (currently it's glued to GRASS
with some ugly shellscripts and stereo needs a bit of rewrite as well)
Currently I use it as follows:
(You may calibrate using any 4+Polygon like TP's etc. which are
visible in at least two photos)
Put a multi-colored cube wireframe of known dimensions out in the
location (level it using some standard method), write down it's
relative coordinates. (used for Image calibration later on)
Take as many photographs as seem appropriate (always with
cube included). (at least 2 photos are necessary)
Calibrate images using known info (relative cube coordinates) within
stereo (display). Triangulate points of interest. ...
with additional import and manipulation within grass to follow.
If there is enough interest in merging stereo to grass, i will
write/rewrite a grassmodule / stereo.
(perhaps as an extension to OrthoRectificationSupport)
Pros:
pretty random Camera placement (cam location hasn't to be known!)
pretty high quality results (depending on calibration points)
one person usage of complete system (it's easy to deploy
a "calibration" object and taking photos of it.)
reusable datasets (Photos taken may be reviewed afterwards
for other - former unknown - topics without having to
survey the points of interest again.)
cheap (A simple camera/scanner system)
fast (doing some snapshots at more or less random positions
really doesn't cost to much time)
interoperates well with GPS/Remote Sensing)
Cons:
currently buggy software / no plug and play module as of now
you can only measure what you can identify (as good/bad as v.digit)
Plans:
Reimplementing stereo within tk and a c library.
Providing hooks for grass and image registration.
Let me know if there is already some tool/module out there (GPL or sim.)
(i.ortho.* doesn't count as it requires camera location as well
as other accurate data not always at hand (according to GRASS Handbook))
best regards,
Christoph Hoegl
(Stereo is a (pretty old) GPL package for stereo photogrammetry))
---------------LSM Entry-----------------------------------
Begin3
Title: Stereo
Version: 0.2
Entered-date: 06OCT97
Description: Stereo-photometrology package. A tool
                for loading up high res grey tiff/targa
                files of stereo photographs and
                taking accurate 3D measurents from them.
Keywords: XLib, X Window System, X11, stereo,
                photometrology, CAD, measurement,
                Cooledit
Author: psheer@icon.co.za (Paul Sheer)
Maintained-by: Nobody
Primary-site: sunsite.unc.edu /pub/Linux/apps/math
                3193kB stereo-0.2.tar.gz
                1kB stereo.lsm
Platforms: Linux, and any Unix clone running X11
Copying-policy: GPL
End
------------------LSM Entry-------------------------------
Hi Christoph,
with a small patch I could compile the
stereo-0.2/widget > diff 3dkit.c 3dkit.c.org
111c111
< #ifdef __i686__
#ifdef __i386__
I have loaded grayscaled tiff from "imagery/spearfish" (gs13.1, gs14.1
aerial photos, exported with r.out.tiff, then xv conversion to grayscale)
successfully into "stereo" program.
It's looking promising for GRASS! However, a direct link to GRASS would
be very useful to determine the control points etc.
BTW: Once as a student I made stereo images from "imagery/spearfish"
http://www.geog.uni-hannover.de/users/neteler/stereo/welcome.html
You need red/green or red/blue glasses to enjoy.
I would welcome to see "stereo/3D" measurement integrated into GRASS.
Please consider to develop such a module.
Many thanks for your offer,
kind regards
Markus Neteler
On Mon, Apr 02, 2001 at 11:41:51AM -0700, C.Hoegl@gmx.net wrote:
Hi GRASSlist,
Pros:
Cons:
Plans:
best regards,
Christoph Hoegl
Begin3
Title: Stereo
Version: 0.2
                Cooledit
                1kB stereo.lsm
Copying-policy: GPL
End
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
