[GRASSLIST:1691] setting multiuser grass enviroment
Hi, I'm a linux sysadmin trying to set up permissions
for using grass with multiple users accounts. I've
started tcltkgrass from root account, but from any
user account gives me permission error.
"you do not have access to any of these mapsets"
I've done the following:
# groupadd workgroup
# mkdir /usr/local/grass-data
and ungzipped many mapsets (leics, weather, ansi,..)
there
# chmod -R 2775 /usr/local/grass
# chmod -R 2775 /usr/local/grass-data
# umask 002
added users to workgroup
$ newgrp workgroup
$ grass5 -tcltk
I've realized that every mapset dir & file needs owner
user permission to start the grass shell, any
workaround?. I'll appreciatte any help, thanks in
advance.
regards
¡Ayudá a los chicos navegando!
En noviembre, Yahoo! dona un plato de comida por cada usuario que nevegue gratis con Yahoo! Conexión.
Conectate ya en http://conexion.yahoo.com.ar
there
# umask 002
$ newgrp workgroup
$ grass5 -tcltk
advance.
Within each location, each user needs their own mapset directory,
which must be owned by that user. Users will be able to read maps in
any mapset, but can only create maps in their own mapset.
You can either:
a) pre-create the mapset directories; as well as creating the
directory, you need to add a WIND file, which can be copied from the
PERMANENT mapset, or
b) make the location directory group writable, and let each user
create their own mapset at the startup screen (however, the tcltkgrass
interface currently doesn't allow this; you have to use the text
interface to create a new mapset).
> there
> # umask 002
> $ newgrp workgroup
> $ grass5 -tcltk
> advance.
You can either:
The tcltkgrass interface does allow this (5.3-CVS and 5.7-CVS).
Some time ago I have updated the startup GUI screen. You can
launch it with:
grass5 -gui
grass57 -gui
[ -gui is an alias for -tcltk which can be remembered more easily ]
It missing in GRASS < 5.3 i.e. all official releases (yesterday we
published GRASS 5.0.3).
It may be a good idea to prepare a GRASS 5.3.0 release to make available
all important new features such as datum transformations etc to the
users. GRASS 5.3-CVS works quite well, so that a new release_branch could
be derived from that.
Markus Neteler
