[GRASSLIST:1692] ps.map grid lat/long
hey all, I am trying to make a postscript map with ps.map but am having a hard
time producing a grid. I am in a lat long location, which I suspect may be the
problem. The script I have tried is as follows
rgb p15r53_b3x p15r53_b2x p15r53_b1x
grid 10000
color indigo
numbers 2 indigo
end
scale 1:100000
sites crdates
color red
desc n
size 0.5
end
end
I have also tried (grid 00:00:30) etc. but no luck. My map is approximately 125
km across. The map prints fine, just no grid. Any suggestions? Does ps.map
produce a grid in a lat/long projection? Many thanks
-ian
> grid 10000
>>> color indigo
>>> numbers 2 indigo
>>> end
> scale 1:100000
> sites crdates
>>> color red
>>> desc n
>>> size 0.5
>>> end
> end
The "grid" command works in lat/lon, but its argument will be in
degrees, and it has to be an integer. Which, for your purposes,
basically equates to "doesn't work".
The command should probably be changed to accept a floating-point
argument; I doubt that there is any inherent reason for using an
integer.
