[GRASSLIST:1712] Re: clustering
Mosix is most effective you have multiple processes, so if you were running
the same program hundreds of times with a different dataset this may be good
(think of flooding scenarios). If you are looking for a speedup of a single
complex function and you have a Multiprocessor box thread the CPU intensive
parts of the code. If you have a complex algorith that has little data
dependency between the elements it may be suitable to split over a cluster
using PVM or MPI.
Its really a horses for courses approach.
Ian Willis
Systems Administrator
Division of Entomology CSIRO
GPO Box 1700
Canberra ACT 2601
ph 02 6246 4391
fax 02 6246 4000
-----Original Message-----
Sent: Saturday, 7 April 2001 7:55 AM
To: rshepard@appl-ecosys.com; ehillmuth@digitalmeridian.net
Cc: grasslist@baylor.edu
Subject: [GRASSLIST:1711] Re: clustering
MOSIX looks like it might allow me to run GRASS on a cluster without
recompiling GRASS for multiple processors, am I right?
I will indeed be trying this in the next week or so. I will be sure to
report to the list what happens. Luckily, I work in a large bloated office
environment which is fully caught up in perpetual windows upgrades, so older
PCs are one thing I have plenty of. Actual GIS education, heck no, but old
computers, no problem :wink:
Lars
Rich Shepard <rshepard@appl-ecosys.com> 04/06/01 04:44PM >>>
On Fri, 6 Apr 2001, Eric Hillmuth wrote:
I had been following the clustering discussion a few days ago and ran
across
this site today:
http://www.mosix.org/
I wonder how useful this kind of clustering framework would be for GRASS
applications. It seems pretty straightforward to set up.
Eric,
  It certainly looks impressively easy! Now, if I had the spare cash to set
up a bunch of linux boxes in a rack, I could test it. :slight_smile:
  Worth looking at it detail, I suggest.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) |
I sort of figured it would come down to what you wanted to do with your cluster.
Mosix looks like a pretty sophisticated way of moving processes around as well a
more or less easy set up (as in no Grass recompiling necessary) but it also
looks like a Mosix cluster would have pretty limited uses as Ian describes.
Either way I'm interested to hear how Lars's efforts go.
using PVM or MPI.
Ian Willis
GPO Box 1700
Canberra ACT 2601
ph 02 6246 4391
fax 02 6246 4000
Lars
across
> this site today:
Eric,
Rich
Eric Hillmuth
Principal
Digital Meridian
http://www.digitalmeridian.net
Phone: 303-809-8972
Fax: 303-443-9427
