My apologies if I have responded to this request earlier. But a quick check of the archives does not turn my response up so I will repost.
On Nov 14, 2003, at 10:59 AM, John Chesnut wrote:
Can you post a summary of:
1) a "clean" version of your OSX configure command.
My configure command was fairly straight forward:
./configure \
--with-postgres-includes=/sw/include/postgresql \
--with-postgres-libs=/sw/lib/postgresql \
--with-gdal=/usr/local/bin/gdal-config \
--with-includes=/sw/include \
--with-libs=/sw/lib \
--with-opengl-includes=/usr/X11R6/include \
--without-odbc \
--with-proj \
2) note on your directory structure for a grass build
I left the directory structure as the defaults. Therefor Grass got installed into /usr/local
truffula:/usr/local/grass5 kirkw$ ls
bin documents fonts locale scripts
bwidget driver include locks tcltkgrass
dev etc lib man txt
3) Notes to the source of the libraries and headers which you had to troubleshoot.
As you can see in the configure script, I installed everything from fink with the exception of gdal (here I used 1.1.9 and configured with the switch --without-python... which I saw as a recommendation in the archives... from Hamish, I think), and grass (which for I used the new stable 5.0.3, configured with the above switches).
The only trouble I had was getting postresql installed with fink. And once I realized that I needed to be installing all of its dependencies from the same unstable tree, that went smoothly as well. Here is what I copied into my local/main/finkinfo directory:
truffula:/sw/fink/dists/local/main/finkinfo kirkw$ ls
passwd.info postgresql-libpqpp.patch
passwd.patch postgresql.info
postgresql-libpgeasy.patch postgresql.patch
Reason: I have been unable to configure/ make the OSX binary, and hope to benefit from your troubleshooting.
john chesnut
If you have any more questions feel free to ask away...
Kirk
