Hello kind list;
I am seeing some odd display behavior in the cygwin bash shell with versions 5.0.2 and 5.0.3 that I have compiled myself, but not with the distributed 5.0.2 cygwin binaries. Below is an example from the g.remove command, but similar problems exhibit themselves in other commands e.g. g.region. The problem is that part of the left portion of the line most of the lines are missing.
5.0.2 compiled by me (missing left'ly chars):
GRASS:~ > g.remove fsh2b
REMOVE [fsh2b]
raster
ader
category
or
istory
MISSING
MISSING
5.0.2 binary distribution (correct):
GRASS:~ > g.remove msh2b
REMOVE [msh2b]
raster
header
category
color
history
misc
fcell MISSING
g3dcell MISSING
I have the newest (possibly too new?) cygwin distribution. Most of the text appears correctly, and all of the modules that I have used appear to correctly. Is there a library that is used for this semi-formatted text that may be out of sync on my system? Or another area that I should explore?
I am running a "straight" bash shell (not Xwin) on Windows 2000.
This is not an urgent problem for me, but I would welcome any help that anyone might be able to offer.
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
Richard Greenwood wrote:
Hello kind list;
REMOVE [fsh2b]
raster
ader
category
or
istory
MISSING
MISSING
REMOVE [msh2b]
raster
header
category
color
history
misc
fcell MISSING
g3dcell MISSING
The code which produces the above listing is in
src/general/manage/lib/do_remove.c:
for (i = 0; i < list[n].nelem; i++)
fprintf (stdout," %-*s ", len, list[n].desc[i]);
fflush (stdout);
switch (G_remove (list[n].element[i], old))
case -1: fprintf (stdout,"COULD NOT REMOVE"); break;
case 0: fprintf (stdout,"MISSING"); break;
fprintf (stdout,"\n");
It appears that fprintf() isn't handling "%-*s" correctly.
I'm not sure how you could get different behaviour for different
builds of GRASS.
Glynn, et al;
I believe that I have found the root of the problem that I outline in the email below. I had been using WinZip to un-compress and un-tar the source archive. WinZip apparently converts UNIX \n into DOS \n\r in files that it identifies as text. I wouldn't think this should matter for C source files, but I am guessing that there may be some files that are sensitive to this.
If I use gzip and tar to unpack the archive before I build, then the resulting binaries do not exhibit the problem. I have been bitten by this conversion enough times in the past that I should have know better!
Rich
> Hello kind list;
> REMOVE [fsh2b]
> raster
> ader
> category
> or
> istory
> MISSING
> MISSING
> REMOVE [msh2b]
> raster
> header
> category
> color
> history
> misc
> fcell MISSING
> g3dcell MISSING
fflush (stdout);
builds of GRASS.
(307) 733-0203
