[GRASSLIST:1725] Point data from dxf file.
Trying to inport point data from dxf files in grass5.0.3, I supposed to use v.in.dxf and made a selection for a specific layer (containing the points I need to import into grass).
The only way to select layer seems to be using the "lines" options, layers are recognized but points are displaied as vertical straight lines.
Is there another way to import those features?
Thanks, Michele.
the points I need to import into grass). The only way to select layer
You might try v.to.sites on the result and see what happens.
You might try loading the DXF file into 'qcad' and only highlight the
layer you want (shade the eyeballs) & re-save a file with only that
layer and then import that.
Hamish
