[GRASSLIST:1733] realtime_gps
Dear Hamish,
As you said I changed -q to -w in your script and now it works
But I don’t know what should I write in “USER_PROJ” ?
Would you please explain it for me in simple language?
Thanks a lot
Maliheh
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://bambi.otago.ac.nz/hamish/m.realtime_gps.sh
[turns out Debian's netcat isn't standard, it has a -q timeout flag]
But I don't know what should I write in "USER_PROJ" ?
$USER_PROJ is the projection parameters used by PROJ.4's cs2cs.
(i.e. everything after the +to)
That is the projection parameters for your current location.
You might look at g.projinfo for some ideas.
see:
http://www.remotesensing.org/proj/gen_parms.html
It's probably better to rewrite the script to use 5.3's m.proj2..
Watch this space, more code is on the way ...
Hamish
PROJ.4's cs2cs.
location.
Thank you so much Hamish for your help.
but in grass5.7 when I use g.projinfo it shows:
can't read "opttype(1)":no such element in array
Now what should I do?
__________________________________
Do you Yahoo!?
http://antispam.yahoo.com/whatsnewfree
Hello
Don't use g.projinfo in 5.7; use the newer g.proj. Specifically,
"g.proj -jf" will give you the projection parameters for your current
location in PROJ.4 format. Type "g.proj help" to see the other options
(there is no man page yet).
Paul
