[GRASSLIST:1752] trouble with reprojecting world map
Hello,
I downloaded the new world map that Markus reworked from the orginial UNESCO
GRID version. It is in lat/long and I would like to reproject it to a
mollweide projection in order to make nicer world maps.
I've created a new location, defining the mollweide projection and trying
several ellipsoids (sphere, wgs84, ...), but everytime I run v.proj to import
the map from the global location, I get a map with lines across the entire
map, and 5 unattached labels.
Is this a problem due to the quality of the data (I know this originally comes
from ESRI data, so I shouldn't expect the best quality), or am I doing
something wrong ? What ellipsoid would you use for a world map in the
mollweide projection ?
Moritz
