I have data from http://www3.wadnr.gov/dnrapp3/dataweb/dmmatrix.html and
http://www.wsdot.wa.gov/mapsdata/geodatacatalog/default.htm for klickitat
county and city of goldendale.
My goal is to query the data for the area of klickitat city and whakiakus
drive. I would also like to be able to create new data based on our
property lot and display it in the same cordinate system as the existing
county/state data, any recomendations on an inexpensive, linux/grass
compatible gis device to collect data?
I am trying to import vector data .e00 from the above urls but I cant seem
to select the correct files for label, points and other requested files in
the import dialog. I cant tell which files are labels, points, polygons,
lines and so forth. How can I tell?
On another import of shp files it asks for the label and attribute fields.
When I use fields from dumping on import, regardless of combination, when
I use the query with mouse, no specific data shows up. Where do I find the
name of these fields? What files are they in?
Also, how do I get the pan/zoom feature to zoom in? It just keeps drawing
white boxes and does nothing else.
One other thing, how would I determine what buildings are within line of
sight of a proposed broadcasting tower?
thanks, nichols
great work grass guys
on our property lot and display it in the same cordinate system as the
existing county/state data, any recomendations on an inexpensive,
linux/grass compatible gis device to collect data?
You mean like from waypoints in a Garmin GPS?
(gpstrans, s.in.garmin.sh, v.in.garmin.sh, ...)
fields. When I use fields from dumping on import, regardless of
combination, when I use the query with mouse, no specific data shows
up. Where do I find the name of these fields?
v.in.shape -d
drawing white boxes and does nothing else.
After setting the first corner with the left mouse button, set the
second with the middle (or both l+r if you only have two buttons).
Hitting the left button again just resets the first corner.
Buttons:
Left: 1. corner (reset)
Middle: 2. corner
Right: Quit
of sight of a proposed broadcasting tower?
r.los or try r.cva.
regards,
Hamish
