[GRASSLIST:178] NEWBIE: GUI problem
ok, I am new to grass and kinda new to linux so please bear with me :slight_smile: I
have installed grass on the linux redhat 9 distribution when i start it
i get the following error message:
  WARNING: The wish command (wish) was not found!
  Please check your GRASS_WISH environment variable.
  Use the -help option for details.
  Switching to text based interface mode.
  Hit RETURN to continue.
  This version running thru the Bash Shell (/bin/bash)
  Help is available with the command: g.help
  See the licence terms with: g.version -c
  Start the graphical user interface with: tcltkgrass&
  When ready to quit enter: exit
  GRASS:~ > tcltkgrass&
  [1] 4995
  GRASS:~ > /opt/grass5/bin/tcltkgrass: line 3: exec: wish: not found
[ 1]+ Exit 127 tcltkgrass
  GRASS:~ >
Does anyone know what this means and how i can fix it?
thanks
alex
[ "wish" appears to not be installed ]
You need to learn and become very comfortable with installing software
packages on your system. On RedHat systems you use the rpm command to
install and uninstall packages. You need to insert your RedHat
installation CD and type *something like*:
# mount /cdrom
# rpm -Uvh /cdrom/RedHat/RPMS/wish*.rpm
Also read the rpm manual: "man rpm"
first try t set the GRASS_WISH enviromental variable
usually the wish is in /usr/bin
All this provided that u have installed the tcltk rpms. Tcl/Tk is needed for the GUI.
So, check your /usr/bin and usr/local/bin.If u find the "wish", set the above variable. If uoy find something like wish8.4 set a link.
Konstantinos Theofilis
# mount /cdrom
Working now, thank you all so much :slight_smile:
Alexandra Panton
-----Original Message-----
From: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu] On
Behalf Of Edmund Blackadder
Sent: 27 May 2003 20:54
To: grasslist@baylor.edu
Subject: [GRASSLIST:231] Re: NEWBIE: GUI problem
needed for the GUI.
:slight_smile: I
it
# mount /cdrom
