I've just downloaded and compiled GRASS5.0.2 (time to get to work again..)
(WinXP) with the following options:
./configure --without-gd --without-odbc --without-fftw
GRASS is now configured for i686-pc-cygwin
Source directory: /cygdrive/c/grass/grass5.0.2
Build directory: /cygdrive/c/grass/grass5.0.2
Installation directory: /usr/local/grass5
C compiler: gcc -g -O2
FORTRAN compiler: g77
NVIZ: yes
X11 support: yes
DBM support: no
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: no
Tcl/Tk support: yes
PostgreSQL support: yes
OpenGL(R) support: yes
ODBC support: no
FFTW support: no
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: no
GLw support: no
NLS support: no
Readline support: no
and then,
make
make install
and everything went according to plan. I successfully started GRASS, and
attempted to start a display monitor and got the following message:
GRASS:/cygdrive/c/grass/grass5.0.2 > d.mon start=x0
ERROR: Graph_Set: can't open Display
No socket to connect to for monitor <x0>.
Problem selecting x0. Will try once more
and got the same message. When I started X11 (under cygwin) and ran the same
commands I got a display window and could display a map. I *do* only want to
run the generic version though (less junk on the WinXP machine to deal
with).
When I installed cygwin (new WinXP laptop) I installed everything, even the
XFree86 files from the cygwin installer, not separately like I recall doing
earlier (a year or two ago). I read from the posting threads there was some
problems getting the monitors working but could figure out if they were
applicable.
In addition, the only command I ran other that the ./configure, make and
make install, was "ln -s /bin/less /bin/more" and have ignored all the other
commands in step 5 so far. I'm sure it's not perfect, but I like to test the
"idiot-proofing" when I do these types of installations.
PS. I did install the dll Mike Thomas sent me on my old Win2K machine
running the generic grass build and it works great. Thanks!
Any ideas?
Jeff.
