[GRASSLIST:1812] newby question
Hello all,
I just started using grass, but I have a little trouble finding some
commands. I am looking for a command with which I can join two maps into
one. I want to join to two gtopo30 maps into one. And the other command
I am looking for is one which can cut out a certain area of a map.
thanks in advance, koos
On Sat, May 05, 2001 at 06:33:38PM -0400, Koos Jan Niesink wrote:
Hello all,
r.patch will paste rasters together.
You can use g.region to set an "area of interest", and if you really
want a subset, it's easy to use r.mapcalc as in:
GRASS ~/> echo "newmap = oldmap" | r.mapcalc
The new map will only contain parts of oldmap that fall within the
current "region" settings. It's worth learning r.mapcalc, since you can
do alot of fairly arbitrary stuff with it (at least with rasters).
Eric G. Miller <egm2@jps.net>
