[GRASSLIST:1815] Mac OS X - Grass 5.3cvs e 5.7cvs binaries download
Grass 5.3cvs and Grass 5.7cvs work in Mac OS X
You need some libraries from FINK:
Download FINK from (http://fink.sf.net)
Go to:
http://wwwamb.bologna.enea.it/forgrass/
and download grass53 and grass57 and other libraries
Read the INSTALL file
Note:
Now Grass 53cvs is complete.
There is one module important for me that it does not work: hdf import via GDAL. Now it's impossible to compile gdal cvs with hdf4.1r5 from Fink distribution.
Please an help
Grass57cvs is very young.
Postgresql module has an error when I compile: the only one.
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it ||/|/| ENEA prot Web: http://wwwamb.bologna.enea.it/ || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
Go to:
Note:
Please an help
Please contact the GDAL developers for this.
Please post the error, so that we can investigate the problem.
Markus Neteler
Yesterday I have compiled new GRASS 5.7 binaries for
Mac OSX. Now using shared libraries - the download
package size is only 8 MB:
http://mpa.itc.it/markus/grass57/macosx/
Markus Neteler <neteler@itc.it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
I installed this binary (on a machine that has 5.0.2 working fine) and got the following error on startup:
dyld: /usr/local/grass57-19_11_2003/etc/lock can't open library: /grass57exp/dist.powerpc-apple-darwin6.8/lib/libgrass_gis.dylib (No such file or directory, errno = 2)
/usr/local/grass57-19_11_2003/etc/Init.sh: line 160: 4747 Trace/BPT trap "$ETC/lock" "$lockfile" $$
Unable to properly access /Users/chris/.gislock57
Any ideas?
Chris
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
Any ideas?
Yes. We have to catch all HOSTTYPE values a Mac could have.
So far "macintosh" and "powermac" are implemented.
What does
echo $HOSTTYPE
print?
For a quick solution edit
search for "powermac" and add your HOSTTYPE there.
Then it will work.
Reason: Mac OSX uses DYLD_LIBRARY_PATH instead of LD_LIBRARY_PATH.
At time your HOSTTYPE is not detected properly in the script.
So please let us know your HOSTTYPE.
Chris
> Cheers
It prints "powerpc"
I will try your suggested fix. Thanks.
C.
Any ideas?
What does
echo $HOSTTYPE
print?
Then it will work.
Chris
On Thu, Nov 20, 2003 at 10:44:00AM -0500, Christopher Fonnesbeck wrote:
It prints "powerpc"
I have updated the package on my site:
Hopefully that's it for a while...
M.
C.
>> Any ideas?
> What does
> echo $HOSTTYPE
> print?
> Then it will work.
> Cheers
> Markus
>> Chris
>>> Cheers
>> Georgia
I installed this binary (on a machine that has grass 5.3 and gdal working fine) and got the following error on the startup of the graphical interface after choosing the location:
Any ideas?
GRASS 5.7.-cvs > Error in startup script: dyld: ps.map can't open library: ./libgdal.1.1.dylib (No such file or directory, errno = 2)
     while executing
"exec ps.map -p"
     (procedure "DmPrint::init" line 14)
     invoked from within
"DmPrint::init"
     (procedure "main" line 30)
     invoked from within
"main $argc $argv"
     (file "/usr/local/grass57-20_11_2003/etc/dm/d.m.tcl" line 789)
If I type from a consol:
./libgdal.1.1.dylib
I have Segmentation fault
Giacomo
p.s. thanks Markus fon the help installing 5.3
Any ideas?
     while executing
"exec ps.map -p"
     invoked from within
"DmPrint::init"
     invoked from within
"main $argc $argv"
Somehow the ./libgdal.1.1.dylib is not found. Does it have the same
name for grass 5.3? Say: check the name of the installed GDAL lib.
If it matches, there is a problem with DYLD_LIBRARY_PATH.
./libgdal.1.1.dylib
sure - it is a library, not an executable. But this indicates that
the lib is existing (which path?).
