On Monday 17 November 2003 16:19, Miha STAUT wrote:
> Hi,
> Why is the following command wrong? The opposite way works without problem.
> GRASS 5.7.0-cvs:/home/ines > db.copy from_driver=pg
> from_database=dbname=nuts\
> from_table=dejanja to_driver=dbf to_database=./ to_table=dej
> dbmi: Protocol error
> WARNING: Cannot create new table: 'create table dej ( ks_ime_d varchar(-5),
> 127 integer, 129 integer, 133 integer, 134 integer, 135 integer,
> 136
> integer, 137 integer, 143 integer, 144 integer, 145 integer, 152
> integer,
> 180 integer, 181 integer, 183 integer, 196 integer, 197 integer,
> 200
> integer, 201 integer, 202 integer, 203 integer, 211 integer, 212
> integer,
> 213 integer, 214 integer, 215 integer, 216 integer, 217 integer,
> 218
> integer, 221 integer, 224 integer, 226 integer, 228 integer, 245
> integer,
> 254 integer, 256 integer, 299 integer, 302 integer, 303 integer,
> 309
> integer, 310 integer, 311 integer, 317 integer, 327 integer, 333
> integer,
> vsa_dejanja integer, kriminalnost double precision)'
> Segmentation fault
> Or is there a command I could use to succesfully export a PostgreSQL table
> to a .dbf table?
> Thanks in advance, Miha StautWhat '\d dejanja' in psql says?
Table "dejanja"
Column | Type |
ks_ime_ | text |
127 | integer |
129 | integer |
133 | integer |
134 | integer |
135 | integer |
136 | integer |
137 | integer |
143 | integer |
144 | integer |
145 | integer |
152 | integer |
180 | integer |
181 | integer |
183 | integer |
196 | integer |
197 | integer |
200 | integer |
201 | integer |
202 | integer |
203 | integer |
211 | integer |
212 | integer |
213 | integer |
214 | integer |
215 | integer |
216 | integer |
217 | integer |
218 | integer |
221 | integer |
224 | integer |
226 | integer |
228 | integer |
245 | integer |
254 | integer |
256 | integer |
299 | integer |
302 | integer |
303 | integer |
309 | integer |
310 | integer |
311 | integer |
317 | integer |
327 | integer |
333 | integer |
vsa_dejanja | integer |
kriminalnost| real |
BTW, from_database=nuts should be OK.
Radim
_________________________________________________________________
STOP MORE SPAM with the new MSN 8 and get 2 months FREE* http://join.msn.com/?page=features/junkmail
