On Tue, May 15, 2001 at 02:58:06PM +0200, Dieter Lehmann wrote:
only an idea...
I'm working a lot with ArcView, there are sometimes strange problems when the
nodes are not snapped, seems, you should check that (eventually in MapInfo).
Even duplicated lines result in pretty obscure behavior.
Try v.digit on your data, that might help.
I don't think, thats only a display problem.
Rich,
yes, Dieter's idea to use v.digit may be a solution:
- check map scale (shouldn't be 1:0 of course)
- check the boundary coordinates in that sheet (N,S,E,W)
Then, after leaving v.digit, the new vector header is saved.
Hope this helps,
On 14-May-01 Rich Shepard wrote:
> I have a vector layer that is imperfectly imported from MapInfo
> (v.in.mif). When I try to interactively zoom in (d.zoom), I get an error box
> at the bottom telling me that the north value must be greater than the south
> value. (Sarcastic comment not provided; the computer wouldn't understand it
> anyway.) But, if I select a larger area, it works.
> Also, if I select a medium-size area, I don't see what I outlined, but an
> open multiple-line figure. I've no idea from where this comes.
> Any ideas what might be going on here?
> Rich
> Dr. Richard B. Shepard, President
> Applied Ecosystem Services, Inc. (TM)
> 2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
> + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
Dieter Lehmann
University of applied Sciences
Schelmenwasen 4-8
D-72622 Nuertingen, Germany
lehmann@fh-nuertingen.de
Phone: +49 (0) 7022 404 Ext. 207
Fax: +49 (0) 7022 404 Ext. 209
Date: 15-May-01
Time: 14:51:24
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
