[GRASSLIST:1842] Grass5 Startup
I have run into a slight glitch with tcltkgrass. I am using Grass5 and
I was attempting to have d.mon startup as a preference when tcltkgrass
is started.
Unfortunately, I did this two or three weeks ago and therefore I cannot
recall the exact steps I followed.
Now when I activate tcltkgrass, I get an automatic d.mon upon startup
and a display window (x0), however, the Main menu is missing.
There is a d.mon error due to the number of colors available but this
has not been a problem in the past. Is there a way to reset the
defaults so that the menu starts up again? I assume a variable is
stored in a file somewhere (maybe xdriver?).
I am running on Redhat Linux and need to spend more time getting
reacquainted with it. Any help would be greatly appreciated.
Thanks
Kirk Schmidt
Hy Kirk,
is started.
If you started a monitor and then exit TcltkGrass with the 'Save Settings'
on, the monitor(s) open at the time you exited saving, will open
automatically again.
The d.mon error is actually what impeeds you to get the menu started.
Here for the reset to the defaults in order to get tcltkgrass menu started
question:
To stop TcltkGrass from automatically loading the monitors, without managing
to start Tcltkgrass, you should change TcltkGrass's configuration file:
- To reset ALL tcltkgrass settings, simply delete the configuration file
   .tcltkgrass (note the "." before 'tcltkgrass').
- To stop automatically loading a given monitor, take the configuration file
   .tcltkgrass , and:
1) replace the monitor(s) state from normal or whatever to an empty string
    ({}). Example on x0:
    replace:
xdriver(x0,window_state) normal
    by:
xdriver(x0,window_state) {}
2) delete the line selecting a monitor. Example on x0:
xdriver(selected) x0
I'm not yet a linux nor grass guru, but for the colors problem, maybe some
ideas to follow:
-starting Xwindow with enough color depths (something like: "startx -bpp 24"
to get 24bit color depth (True Color, like Xdriver)
-if you have old grafic card (video RAM<4Mb), you might be limited in the
number of colors available for a given resolution. (e.g. not able to start X
with 24bit colors and 1024x786 resolution). reduce the resolution and beware
starting applications using a lot of colors (e.g. netscape) before the Xdriver
-starting the Xdriver with nlev option (Number of color levels for each
R/G/B (by default: nlev=32: 32768 colors)) Example: d.mon start=x0 nlev=24
(cf.: d.mon manual page)
Thanks
Kirk Schmidt
Hope this will help
In Kindness
Karine
Karin(e) ZUERCHER University of Geneva, Switzerland
                                Diplome es Sciences de la Terre
                                         GRASS user
Email: Karine.Zuercher@terre.unige.ch
is started.
Maybe there were sufficient colours available in the past. Quit any
colourmap-hungry programs (Netscape in particular) and try again.
There is no config file for XDRIVER.
One thing which you neglect to mention: which version of GRASS 5 are
you using? GRASS 5 is still under development; we need to know the
snapshot date.
If you're using a recent snapshot (after Apr 21), note that XDRIVER
has been undergoing significant changes recently.
