Hello,
I'm trying to use linebreaks in the 'text' command in ps.map, but I just can't
get them to work.
On the html-manual page it says that putting '\en' into the line will produce
a linebreak. I've tried this and
it will just write 'en'.
The manual then goes on to give an example (e.g. USA\|\enCERL). So I tried to
put in '\|\' en instead of \en, but this just produces a '|en'.
Could someone enlighten me ?
Moritz
mlennert@club.worldonline.be wrote:
Hello,
can't get them to work.
produce a linebreak. I've tried this and
to put in '\|\' en instead of \en, but this just produces a '|en'.
Moritz
That is bug in manual, it should be '\n' as usual in C and others.
Unfortunately text is always justified to the left.
I din't fix that in repository because I cannot somehow connect (my
problem here probably), I'll fix later from my home.
Radim
