[GRASSLIST:1854] Can't open the monitor with grass5.0.0pre
Dear grasslist
I am running RH 7.1 and just compiled new grass5.0.0pre1.
I have problem vith the monitors, Actually the monitor opens, but i
cannot draw anything on that.
During the compillation I got the response
checking GL/gl.h and GL/GLwMDrawA.h... configure: warning: *** Did not
find GL/GLwMDrawA.h
Should I edit the header file to find that GL or is that missing in
RH7.1 or in my computer.
Many thanks for you time.
Best regards
Seppo Kaitala
Merentutkimuslaitos, PL 33 (Lyypekinkuja 3), 00931 Helsinki
Institute of Marine Research, PO Box 33, FIN-00931 Helsinki, Finland
tel. +358-9-613941 fax +358-9-6857 638
Is the region set correctly? Can you provide an example session?
find GL/GLwMDrawA.h
This has nothing to do with the monitor; GL/GLwMDrawA.h should only be
required for grid3d (GMSL/g3d), which isn't part of the release.
No; you can ignore the warning.
