hello,
i want to use the graphic for grass 5.7, I used the
d.m command but the result is:
Error in startup script: ps.map: error while loading
shared libraries: libpq.so.3: cannot open shared
object file: No such file or directory
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 27)
invoked from within
"main"
(file "/home/softgrass/binnb/etc/dm/d.m.tcl" line
765)
please can you help to resolv the problem.
thank you.
___________________________________________________________
Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
Yahoo! Mail : http://fr.mail.yahoo.com
On Fri, Nov 21, 2003 at 01:03:32PM +0100, hamdi ines wrote:
hello,
This indicates that either PostgreSQL is not installed or
a different version.
while executing
>"exec ps.map -p"
invoked from within
>"DmPrint::init"
invoked from within
>"main"
765)
thank you.
