[GRASSLIST:1884] problem with d.mon
Hello to all,
My OS is window2000 pro.; I installed cygwin, Xfree86, grass5, tcltk. And I
think tcltkgrass turns correctly.:-). 3 weeks ago, I can open monitor with
grass:~> d.mon start=x1.
But now I get :
No socket to connect to for monitor <x1>.
Problem selecting x1. Will try once more
grass:~> using default visual which is TrueColor
ncolors: 65536
ERROR: Can't bind to socket: error "Bad file descriptor"
How can I fix this problem ?
Thank you in advance for your advices.
Karine
But now I get :
ncolors: 65536
Look for a directory called /tmp/grass-<username>, where <username> is
your Cygwin username, as reported by "whoami". Check that you can
write to that directory. Delete any files (actually, sockets) from
that directory.
