[GRASSLIST:1897] postgresSQL interface
I have downloaded the binary version of GRASS 5.0 pre1 and it works fine.
I have met only two problems. A little one is: the script grass5 is not
copied in /usr/local/grass5 then you must do it manually.
A big one is: where are the modules of postgresSQL interface? Why they are
not included in the binary package?
Are they in the "russian version of PostgresSQL/GRASS" interface? What have
I do to install and work with this interface?
Sorry for my boring questions but I am completely novice both in postgres
and postgres/GRASS
stefano
The "grass5" script should go in /usr/local/bin, so that it is in the
path. Note that /usr/local/grass5/{bin,scripts} shouldn't be in the
default path; these programs can only be run from within GRASS (which
adds these directories to the path).
