I am trying to do a rather simple reclassification of a stream layer, using stream codes as a unique index between the map and the postgresql table, but get the following:
GRASS:~ > v.reclass.pg -d streams key=segment_ta col=stream_ord tab=stream_d where='stream_ord>3' output=big_streams type=line
ERROR: 1706010416A0001000.00=5
- invalid reclass rule
'segment_ta' is the column in the table corresponding to the values in the map layer, and stream_ord is the column that I'm using for the reclassification. This seems correct. I dont know what this error means, so I'm hoping someone out there can clarify this for me.
Using GRASS 5.0.2.
Chris
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
