I have a problem with v.digit in grass 5.7.
v.digit works well but I cannot to display a
raster map in background.
When i write "d.rast map=***" in the background
command line of the v.digit window the output
display say: map does not exist
It refers to raster map but the raster map
exists.
Can someone help me?
Thank you
Leonardo Lami
exists.
Do you run the v.digit from GUI (TclTk) or command line?
I think that GUI does not work well if parameters have spaces.
Try also to add d.rast later in v.digit dialog.
Radim
