Dear Grass-list
I have a 1 km resolution raster map in which each cell contains the area of
woodland habitat; from this I'd like to create a 10 km resolution map in
which each cell contains the sum total of all 100 1-km cells in the
original map. The r.surf.idw functions use inverse distance weighting,
which isn't appropriate in this instance. Using Grass 5.0.2
Many thanks in advance
Roy
