[GRASSLIST:1955] help please
Hello! My name is Hoover Serna I'm from Colombia and I'm user of grass4.2.1
I download grass 5.0.3 and i install it in my Linux system (Red Hat 7.0
kernel 2.2.16-22).
I can input Location, Mapset and Database, but when i press Esc Enter the
following message appears:
"/usr/local/grass5/etc/Init.sh: GISDBASE: parameter null or not set"
What can I do?
Thank you for your attention and help.
My e-mail adress is hserna8@hotmail.com
Thanks again.
_________________________________________________________________
MSN Amor: busca tu ½ naranja http://latam.msn.com/amor/
kernel 2.2.16-22).
GISDBASE is set from a value saved in .grassrc5
You can do either of the following:
1. edit .grassrc5 and add a line such as:
     GISDBASE: /path/to/your/data
2. hide .grassrc5 by renaming or moving it. This will cause GRASS to prompt you for Location, Mapset, and Gisdbase the next time you start GRASS.
Regards
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
