[GRASSLIST:1963] no rule to make shapefil.h
After updating grass57 and 53 source from CVS to fix the DYLIB problem on OSX, I get the following:
gcc -L/usr/local/lib -L/sw/lib -L/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/lib -dynamiclib -Wl,-flat_namespace,-U,_cuserid -undefined suppress -L/usr/local/lib -L/sw/lib -L/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/lib \
         OBJ.powerpc-apple-darwin7.0.0/edit_cats.o OBJ.powerpc-apple-darwin7.0.0/edit_cellhd.o OBJ.powerpc-apple-darwin7.0.0/edit_hist.o -lgrass_gis -lgrass_datetime -lintl -lgrass_vask -o /usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/lib/libgrass_edit.dylib
external
bwidget
if [ ! -d /usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/bwidget ]; then mkdir /usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/bwidget; fi
tar cf - images/* lang/* *.txt *.tcl README.grass | (cd /usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/bwidget; tar xf -)
shapelib
make[3]: *** No rule to make target `shapefil.h', needed by `/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/include/shapefil.h'. Stop.
make[2]: *** [subdirs] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
Seen this before?
Thanks again,
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
lib \
external
bwidget
if [ ! -d
bwidget; fi
bwidget; tar xf -)
shapelib
Seen this before?
Did you run
make mixclean
during you update procedure? The complete procedure is explained
in the INSTALL file of 5.7:
UPDATE OF 5.7.x
Assuming that you want to update your current installation from
CVS, you have to perform a couple of steps. In general:
- clean the links to 5.3.x
- update from 5.3.x CVS HEAD (the 5.3.x code)
- update from 5.7.x CVS (the 5.7.x code)
- recreate the links to 5.3.x (make mix)
- configure, compile
In detail:
cd /where/your/grass530/lives/
cvs update -dP
cd /where/your/grass57/lives/
make mixclean
cvs update -dP
make mix
configure ...
make
Hope this helps,
