Hi
I use the PNG driver to generate PNG images.
How can I zoom non-interactively (i.e. without a mouse) ?
I want to display some raster and vector maps and then zoom (or pan) into
the result,
and end up with a PNG file.
Also is it possible to store maps of the different resolutions within GRASS,
and if you want to zoom in, to switch to the map of greater resolution.
Any help would be greatly appreciated.
Many thanks in advance
Riaz Randeree
the result,
Change the region with g.region then re-draw the maps. If you want to
zoom whatever happens to be on the active monitor, you can run d.save,
modify the g.region command in the output, then execute the result.
Not automatically; you would have to explicitly select the map based
upon the current region.
