[GRASSLIST:2021] conversion of sites to 5.7 from 5.0
I am trying to convert some sites over to version 5.7 vector format, but am unable to use v.convert. I get the following:
GRASS 5.7.-cvs:~/Research/INLAS/GIS > v.convert input=bridges output=bridges
ERROR: Input vector was not found.
Yet, when I list the sites, I get:
site list files available in mapset PERMANENT:
bridges hatchery recreation
What am I missing?
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
output=bridges
Did you run
  g.list vect
or
  g.list oldvect
Note that your 'bridges' map must be present in the old vector format.
Since you refer to 'sites', v.in.sites might be the right module.
v.in.sites help
Description:
Converts a GRASS site_lists file into a vector file.
What am I missing?
C.
Markus Neteler <neteler@itc.it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
output=bridges
What am I missing?
v.in.sites
Radim
