On Thu, 18 Dec 2003 10:12:51 +0100
"javier garcia - CEBAS" <rn001@cebas.csic.es> wrote:
Hi Hamish,
thanks a lot for the attached.
Is it possible that the script has an error?
I've run it and I receive a lot of messages like:
./reclass_scrip.sh: : command not found
Best regards,
Javier
Yes, very likely there's an error. I didn't actually test the script.
try replacing
i=`expr $i + 1`
with
i=$(($i + 1))
and see if that works.
Hamish
> > The problem is to pass values of reclassification rules
> > to r.reclass. I've tried:
> > But this doesn't work. I think that this could be also with a bash
> > script, but I don't know anything about bash.
> It is actually pretty clean with Bash, try the attached.
#!/bin/bash
# reclass script
I'm sorry, Hamish. This still does an error. I even have commented nearly
everything to find out the source of the error. But even doing it for a
single map gives an error:
#!/bin/bash
# reclass script
# i=1
# while [ $i -le 25 ] ; do
r.reclass input=imagen1end output=imarec1end << EOF
253 = 192
252 = 96
251 = 48
250 = 24
249 = 12
221 = 8
193 = 7
165 = 6
133 = 4
102 = 3
70 = 2
39 = 1
* = NULL
end
EOF
# i=$(($i + 1))
# done
# if you want the maps to be 01,02,03,..,09,10,11 add this line:
# MAP=`echo $i | awk '{printf "%02i", $1}'`
# echo $MAP
ERROR: 253 = 192
- invalid reclass rule
Perhaps a modification in the format for reclassification rules?
Javier
> Hi Hamish,
> Best regards,
> Javier
try replacing
i=`expr $i + 1`
with
i=$(($i + 1))
Hamish
> #!/bin/bash
> # reclass script
> i=1
> r.reclass input=imagen$i output=imarec$i << EOF
> 253 = 192
> 252 = 96
> 251 = 48
> 250 = 24
> 249 = 12
> 221 = 8
> 193 = 7
> 165 = 6
> 133 = 4
> 102 = 3
> 70 = 2
> 39 = 1
> * = NULL
> end
> EOF
> i=`expr $i + 1`
> done
#!/bin/bash
# \240reclass script
# i=1
\240 \240 \240 \240253 = 192
\240 \240 \240 \240252 = 96
\240 \240 \240 \240251 = 48
\240 \240 \240 \240250 = 24
\240 \240 \240 \240249 = 12
\240 \240 \240 \240221 = 8
\240 \240 \240 \240193 = 7
\240 \240 \240 \240165 = 6
\240 \240 \240 \240133 = 4
\240 \240 \240 \240102 = 3
\240 \240 \240 \24070 = 2
\240 \240 \240 \24039 = 1
\240 \240 \240 \240* = NULL
\240 \240 \240 \240end
EOF
The problem is that you have non-breaking space characters (octal 240,
decimal 160) in the script, which r.reclass won't understand. These
characters are shown as \240 above.
Those characters probably look like spaces in a text editor, but won't
be treated as such by many programs (including r.reclass). You need to
change them to spaces or remove them.
The problem were the non-breaking space characters
I think I should learn bash
Thanks, and best regards
Javier
> #!/bin/bash
> # i=1
> EOF
