[GRASSLIST:21] GRASS and APT-GET
May I install GRASS using APT-GET (Conectiva Linux or Debian Linux) ?
Background:
apt-get is an intelligent frontend to dpkg,
the Debian GNU/Linux packaging software.
apt-get can download or use packages from different sources.
You could only use apt-get if somebody has made Debian packages
for grass. To my knowledge there is an old version of Grass (5.0.0pre4-1)
packaged in the official Debian repositories.
I'm not aware of newer builds wether officially or inofficially.
5.0.0pre4-1 is rather old, so I would not really recommend trying it.
Short answer: No.
If you are looking for prebuild packages which run on Debian,
one options is to download the prebuild binaries or use
the RPMs of the FreeGIS CDs which are tested on Debian and
can be properly with the packaging system using alien.
  Bernhard
I have a debian package of the grass 5.0.1
Add the lines:
deb http://www.talha-mar.com.br/linux/debian ./
deb ftp://ftp.debian.org/debian/ unstable main non-free contrib
in the sources.list file
and
# apt-get update
# apt-get install grass
Sandro.
On Thu, 15 May 2003 11:42:45 +0200
Background:
Short answer: No.
  Bernhard
Sandro Klippel <sandro.klippel@talha-mar.com.br>
talha-mar projetos ambientais
Conselheiro d'Avila 190
Porto Alegre,RS 91040-450
+55 (51) 3344-7451
w w w . t a l h a - m a r . c o m . b r
Short answer: No.
Actually I am using exactly this package from testing (recompiled on
woody with postgresql support switched on; it is 4.99+5.0.0pre4 to be
exact) and it seems to work more or less OK (patch and diff file are
available on http://www.ceplovi.cz/matej/progs/debian).
Are there any major bugs which I should be afraid of?
However, certainly if anybody creates last stable grass for woody,
I would be very happy to upgrade.
Matej
Matej Cepl,
GPG Finger: 89EF 4BC6 288A BF43 1BAB 25C3 E09F EF25 D964 84AC
138 Highland Ave. #10, Somerville, Ma 02143, (617) 623-1488
> Short answer: No.
I believe there are some, check the Changelogs for the
up to the curren tGRASS release.
The FreeGIS CD RPMs work on woody.
Thank you very much for posting the compiled binary of GRASS
5.0.2 for Cygwin/Xserver to the grass mirror sites (I
downloaded from http://grass.ibiblio.org)
The additional functionality, especially d.vect.area and
v.to.pg, are a great help.
Thanks very much.
Best regards,
Michael
Michael Ash, Assistant Professor
  of Economics and Public Policy
Department of Economics and CPPA
University of Massachusetts
Amherst, MA 01003
Tel 413-545-6329 Fax 413-545-2921
Email mash@econs.umass.edu
http://people.umass.edu/maash
On 2003-05-17, 02:23 GMT, Bernhard Reiter wrote:
I believe there are some, check the Changelogs for the=20
There doesn't seem to be anything which should make a problems for me
(working with vector files and psql for presentation of data).
Cool -- thanks. I will try it when I will finish the current project.
Matej
